TwinTurbo.NET: Nissan 300ZX forum - And replacement o-rings are dirt cheap at Sears hardware
dogpile
on November 29, 2010 at 1:33 PM
Threads won't decay unless cross threaded. (n/m)
posted by BigTDogg (MA)
on November 29, 2010 at 11:35 AM
or somewhere similar. If you're that concerned about them going bad, buy a few at once instead of just the ones you need that second. You'll be out $5 for a lifetime supply of them.
Balance Tube.
scottyfender
21:02:40 11/27/10
j30 balance tube? (n/m)
mogaffar
21:04:58 11/27/10
thats what I use on my NA (n/m)
toykoz32
21:58:29 11/27/10
After a quick google image search...
Roundabout136
22:01:24 11/27/10
Can you use J30 tube on a TT or only NA? (n/m)
ZXoltan
06:49:12 11/28/10
TT as well but you will need a 94+ upper plenum and
07:09:09 11/28/10
Or perhaps a 93+ non-turbo one ??? (n/m)
Fast300
00:33:43 11/29/10
As long as it has the mounting points for the throttle
06:57:30 11/29/10
why? 4 bolts and an idle hose clamp
nissansx
11:07:04 11/28/10
2nd ..plus J30 balance tube is ugly (n/m)
KongZTT GT28RS MD
11:09:03 11/28/10
2nd and 3rd.. ^^ (n/m)
Halo TTZ
12:15:19 11/28/10
4th, way ugly. (n/m)
Draker (Eugene, OR)
12:28:03 11/28/10
oops - *5 (n/m)
nissansx
12:31:01 11/28/10
Two bolts, three nuts, three hoses
Fast300
20:01:58 11/28/10
oo semantics... AIR REGULATOR hose = idle hose (n/m)
nissansx
20:12:22 11/28/10
Ok, still 3 nuts and 2 bolts
Fast300
22:50:40 11/28/10
The rubber o rings must get bad after a certain amount...
scottyfender
22:57:21 11/28/10
11:35:43 11/29/10
And replacement o-rings are dirt cheap at Sears hardware -
dogpile
13:33:31 11/29/10
